krust anygood?
Ok guys seen that chemical stuff called krust rust remover, I am going to get my car touched up in couple of weeks I am doing the prep work what is this stuff like got abit of rust in the arches and drivers side sill, under the rear lights and in a corner of the drivers door small bits really but does it work and for how long? Cheers
  • Views 1.6k
sand the rust until its gone , use a dremel to clean out the pits , then a zinc primer
none of these lotions work as advertised
i started off just tidying her up a little and u have sen the state of her now be careful u dont get caried away , i used sum loctite stuf
I wish I could get carried away mate LOL I haven't got the funds to get carried away haha just as I thought elbow grease to bare metal and take the pits out, should I use abit of filler before zinc prime?? Cheers for help so far!
i i used one of those steel wheels , rust remody fillerd then primed , remember dont get un primed filler wet or it will expand
I tried that krust once on my old valver, had a rusty bit on the passenger door. Didn't cure it by any means but regular application stopped it in its tracks.
If your getting your car touched up though I'd sand the rust back or it will just reappear again.
