Quote for timing belt... seem reasonable?
Booked the Polo (1.4 8v 96') in for timing belt at a local VAG specialist, Volksparts. I have heard good things about them altho never actually used them before as I do most jobs myself.
Quoted £129, just wondered if that sounded reasonable to everyone. Booked it in for Wednesday.
Edited by ben_reza
  • Replies 28
  • Views 2.2k
Booked the Polo (1.8 8v 96') in for timing belt at a local VAG specialist, Volksparts. I have heard good things about them altho never actually used them before as I do most jobs myself.
not too bad at all ...I got timing belt done at same time as getting head gasket skimmed as it was kinda sensible to do it while in there iykwim and paid £332 the lot ...used local independent place I have always used http://www.murts.co.uk
with parts?
with parts?
oh yes with parts ...I will only order my own parts if I have to as in when dealing with strange mechanics in NE Scotland
Is it worth doing the water pump at the same time? chatting to a lad at work and he reckons life span of a water pump is usually the same as the belt, so worth doing both at same time.
The car has only done 17k, but its 13 year old so replacing belts due to age not milage.
Edited by ben_reza
probably if you can get it done for not much more ...and you jammy so and so with only 17k on a 13 year old ...what is it ???
probably a good idea to change the waterpump (make sure its replaced with one that has a metal impeller rather than a plastic one)
its actually a pretty easy diy job and not as hard as many think, but £130 to have it doen by a garage is reasonable money
Just a very lucky find on flea-bay last year. Got it with only 8k on the clock, and full service history. Some old girl had it from new. history was quality- between services in 2003 and 2004 she only did 150 miles. I did more than that driving it home from where I picked it up!
Ran it for 6 months now and going to give it a big service next week (apart from belt which I didnt fancy doing myself!)
pics then so we can drool !!!!
Yeah just been having a look at them, not mega expensive. So does fitting a water pump involve removing the timing belt i.e. worth getting garage to do while on with belt, or job I can do when I get car back?
I have the Haynes manual at home but thought i would ask.....
well the pump is used to tension the belt, so the belt has to be slacked off to change it. so you may as well swap them both at the same time
http://www.clubpolo.co.uk/forum/index.php?...129486&st=0
Thread from when I bought it.
Looks a bit different now, lowered 60/40 on 15' OZ 6 spokes, 6n2 rears and clear indicators all round. :thumbsup: Oh and some chav keyed it. :thumbsdown:
Thanks, I will get garage to do that while they are on in that case.
I'm planning on doing a pretty thorough engine service: oil/air/fuel/pollen filters, spark plugs, oil, check rotor arm and dizzy cap (I replaced HT leads when I got it). Is there anything else I want to be doing?
Edit: ....and checking brakes!
Edited by ben_reza
iirc a timing belt at audi is 800 quid....129 seems fine!
definitely get them to do the waterpump at the same time, it's madness not to. If it fails it'll cause just as much damage as the belt snapping.
Give them a call and waterpump supplied and fitted and coolant refresh will be an extra £55. Had a quick scout and cheapest I can buy a pump is £30+, then have to fart on bleeding system etc, so just gonna get them to do it.
excellent news ...sounds like you have a good garage there Fiona x
yeah that's a bargain
Thats pretty cheap i reckon!
And yeah.....change the water pump whilst your at it, it'l probably save you alot in the long run.
Called up local Andrew Page and Part Co, pricing rest of service kit. Part Co was cheaper by about a tenner overall.
Pollen Filter £6
Oil Filter £2
Air Filter £5
Fuel Filter £6
Sparks Plugs £3 each
5L 10/40 Oil £11
Think thats my job for next weekend sorted then.
a 1.8 8v Polo, I'm amazed you got a timing belt kit for it :lol:
I've just realised! :lol:
do'h- edited above :-D
I wouldnt buy 5 litres of oil for £11. You get what you pay for. :)
Volksparts get there parts from Euro Car parts ;)
timing belt KIT £28.65+ vat
water pump £27.37+ vat
but they are a pain in the .... to do so not a bad price
Edited by spoofer
