a flush boot for my 6n
well basically i want to get my boot flushed in a couple months, handle and badge, just roughly how much this would cost including it being sprayed back to normal after, 250 -300 maybe? Cheers
  • Replies 9
  • Views 1.7k
More like around £150 - £200 mate go around a few bodyshops see what they quote. Make sure they weld the holes up though!!!
It will cost you 180ish, but they may ask you to fit the solenoid yourself.
I have been quoted 280 quid to repair my boot, then smooth it and repaint it.
I have to fit the solenoid myself.
£50-£60 tops if you do it yourself...
i would be taking it to a bodyshop as no way i could do it myself, i would not have a problem with fitting the solenoid popper isn't rocket science :-D cheers people
what colours the car? white by the looks of it? what do you want smoothed off? handle,badge and recess?
its DIY able for a lot of folks buddy
yeah might leave the recess not to sure yet, i wouldn't do it myself i don't have a clue when it comes down to bodywork.
EDIT: yeah white mate
Edited by dub17
The other thing is that with a smooth boot on a 6n a mk5 one looks better as the rear window is smoother around the wiper. So when removed the hole blends in better :)
and the mk5 is a perfect fit in the 6n?
need to extend the small panel under the rear lights by like 5mm or so to et it all flush and ideally fit mk5 lights as well :)
unless you can get a cheap boot buddy and ill see what i can do for you ;)
Edited by mad_will
