Painting rear axle and other bits
As above I've decided to spend some time on the polo. The previous owner removed the iner arches so I've protected them with underseal and started the underside of the car. I'm wanting to paint the rear axle beam with the backing plates but wasnt sure which paint to use? Would spary tins be best or black hammerite? It doesnt need to look perfect. Any help appreciated.
  • Views 774
wire wheel and brush off the shittydirt and rust then either spray or brush on. Plastikote cans seem to be quite good and hold up well under cars, use hammerite if you NEVER want to paint it with anything else
Ok thanks, it doesnt need to be perfect just dont like all the rust so its just to tidy it up abit
