6n2 electric problems..
Hi Guys, been having a few electrical problems recently which I/no one else can seem to figure out.
First of all the drivers side window switch stopped working, then did, didnt etc so thought it must just be the switch. the central locking then stopped working and became very temperamental too as it does occasionally work.
The passenger side window works fine and so does the central locking if i use the key in that door. so just the drivers side that has problems!
Door cards have been off and checked all wires/connections etc and all seemed fine. haven't yet located new window switches (damaged in removal!)
Would appreciate any help at all :)
  • Replies 27
  • Views 2.7k
The central locking pump might need replacing
thanks mike but the pump is fine, it would work all day long if I used the passenger door to lock it
Sounds like the lock barrel on the driver's side has detached from somthing, or maybe the lock barrel needs replacing on that door
Have you got water in the fusebox by any chance?
Dodgy relays?
Edited by hustler2257
Dodgy relays?
there is a chance since I haven't checked it, will do that this evening thank you.
where would I find relays? sorry..
Dodgy relays?
You'll find the relays near the fusebox
There's no need to apologis as i dont know where they are myself.... :lol:
Can anyone shed any light on this please?
Dodgy relays?
thanks will have a look and *hopefully* have some luck
any ideas where to find the drivers side window switches? no-one crashes 6n2's in scotland!!
Dodgy relays?
You could ask if anyone is selling the window switch in the wanted section on here
Dodgy relays?
I did a couple months ago with no luck, worth trying again tho, cheers
No problem :)
got new switches and can now work the passenger side window :) but still nothing happening with the drivers side!!! central locking is currently working, couldnt find water etc anywhere and relays are also fine
have no ideas on this at all so will need to get an auto electrician to have a look i think, its getting far too annoying now :(
no more ideas?
Have you checked the wirers in the rubber casing going from the door to the car.
I had a snapped wire there before, which operated the window.
Edited by lebon
yeah there all in tact thats the first place i checked. when the window first of all broke it wasnt just as simple as not working cos it would work one day then not the next etc..until it finally gave in and now doesnt work at all. I thought maybe it was just the wiring for the window but then the central locking and mirrors started to do the same so it seems to be everything to do with the drivers door.
never heard of something so strange before lol
Yea thats what happend to me, the window worked occasionally before going completely.
The central locking switch inside the car didn't work either.
Changed the switch and it turned out to be a snaped wire.
Not sayin it is the problem but sounds very similar.
ah right i see. when you say you changed the switch you mean the plug inside the door??
Think it was a brown wire.
Edited by lebon
And had a snaped wire in here.
lol not sure if i should be offended that you used the pictures.
thank you, i changed the switch so will check all the wiring again :)
No you shouldn't, I just find it easy to explain this way Lol.
Edited by lebon
I'm experiencing the exact problem at the moment.
Does anyone have a solution??
PLEASE
PLEASE
PLEASE
the problem on mine was indeed the wires in the door plug, four of them had snapped so I have temporarily soldered them together til the other half gets round to rewiring it!
PLEASE
Great. i'll have a look later.
can you please explain what you mean by door plug????
PLEASE
when you open the door there is a large black plug next to the hinge which runs wires from the car
