Spraying question?
How easy is it to spray with a compressor? I am fairly competent with rattle cans but am wanting to do my whole car, my dad has the equipment i can borow but i don't want to start if it is going to be hard. I'll be looking for a fairly good finish, not perfect but pretty good.
  • Views 896
It is going to take time, and it is fairly difficult, which is why it is expensive to get done properly.
ALOT of prep work to be done, and you'll need a dustfree environment, not something you can do outside.
Yes, its going to be hard. Very hard if you have never done it before. You need loads of practise 1st really to get used to it all. completely different to using a can.
It takes years and years of experience to get a really good finish. Or just some bloody good luck :lol:
It all depends on what you are happy with though really, if you don't mind a rough/not perfect finish then go for it.
Quick tips:
Try to create a de-humidified environment.
Make sure it's not too cold or hot.
Try to get a dust free environment.
Always start the spray stroke off the panel and sweep on to it in a constant speed single motion and only release when faced away from the panel to avoid spatter.
Also, just remember the distances, take your time with it.
Most off all, preparation is key. Make sure it is ALL sanded down and all body work corrected as best you can for the best finish and clean off all surfaces with paint preparation wipes beforehand.
