Need some help with ideas i have
Well after all ideas for my G40 fell through and a long talk with my dad we have come up with something for my polo
i need to know if the 1.4 golf engine will fit straight into the polo same engine mounts etc and if the old polo gearbox will meet up and make love to it ?
basically the plans will be :
1.3 GT or 1.4 Golf engine rebored to the max,
have everything balanced within the engine (crank flywheel pistons etc)
Bigger (big) valve head
Twin 40s / 45s , or maybe bike carbs ?
268 cam or maybe larger
4 branch to straight through
and other little bits and bats.
so any help on the 1.4 engine is much appreciated.
Also is there any major diffrences between the GT block/head to the standard 1.3spi, (Strength and max bore it can take etc) because at the end of the day its going to be a carbed engine so i need to know if their is any major advantages of a GT engine over a 1.3 SPI
having looked at this option it will sound amazing and hopefully go like stink, and be pretty unique in doing so. Also cost wise it will end up abit cheaper
didnt know were to put this topic guys :( thanks in advance to all you clever bofins out there :) i will be doing research myself I'm not trying to be lazy with this post. Before anyone flames me !
also i would like thank anyone in advance for any response they give :)
Edited by boomzor
  • Views 999
Hmm, for a 'budget' build you are going to get raped for pistons. Maybe you would be better off sticking with the standard ones?
Ideally for a bit more power you could do with upping the compression ratio slightly. I would start by measuring the piston crown/cyl head clearance to see if you can skim the block a bit. Because the pistons are dished you can always skim the block and the pistons by an equal amount (if there is not a large enough squish band to reduce) and still see a rise in compression ratio. Then you need to check the clearences on your new big valves (with your new big cam) and probably machine the piston valve cutouts a little to take the valves, as your pistons will now come closer to your head/valves because of the block skimmage!
You also need to consider the effect (although probably highly neglegable) that skimming the block will have on your cam timing. And if nececcary use an adjustable/vernier pulley to compensate.
GT head is the same as your SPI one apart from most GT heads have double valve springs. These allow your valve train to rev higher without valve bounce. I'm guessing these are a good idea to fit to your head.
The 1.4 ABD block will bolt right in and mate to the gearbox AFAIK. You will probably want to fit either a G40 clutch or one off an early mk4 16v polo. Both are 200mm friction plates.
If you use carbs make sure you set them up correctly. Many people fit and forget, whats the point of fitting performance carbs and then not jetting them to give you the best performance?
I'm in a similar situation as boomzor except my mk3 Polo currently has the tiny 1.0 engine. My first plan was a 2.0 Golf engine, but quickly put that idea in the bin due to the amount of work needed to get it to fit.
My next plan was a G40/GT engine but Tommo32, you say the 1.4 ABD block from a Mk2 Golf will fit? Exactly same engine mounting? If so, this would give me a quick option for an engine as a friend of mine is getting rid of a Mk3 1.4 Golf and he said I could have the engine... eager to know!
If you visit the engines section, in the FAQ possibly. There is a thread that goes through the whole thing.
Be aware that the ABD is only 60bhp standard though.
Cheers! Not expecting it to be the powerplant that I'll eventually want, but something a little more than the 1.0 as standard. That and the head gasket has gone on the 1.0 so it's either repair or replace...
I'm looking at best performance on a mouse engine and i have around 750 quid for it
so its not really much of a budget
if i humped all this together what what be the best option for a gearbox, any uprated ones that would fit and do it even more favours ?
sell the cl for 500, ad it to the 750 and buy something faster
