Voodoo Warrior 4 Channel Amplifier 400W Silver
Voodoo Warrior 4 Channel Amplifier (400W)
Silver
V400.4 Features
4 Channel Award Winning Bridgeable Amplifier
100 x 4 or 200 x 2 Watts RMS @ 2 Ohm
1600 Watt Peak Power
Military Grade Components
Black/Silver Finish
Heat Dispersing Fin Casing Design
Gold Plated Terminals
Remote Gain Controls
Overload, Thermal and Short Circuit Protection
Bridgeable & TRI-Mode Operation
Soft Start Feature
Subwoofer Variable Crossover
Double Side Epoxy Through Hold PCB Board
High Efficiency PWM Power Supply
Dual Colour Status LED (Red/Green)
V400.4 Specifications
RMS, 4 Channel, 4 Ohm Load *
80W
RMS, 4 Channel, 2 Ohm Load *
100W
RMS, 2 Channel, 4 Ohm Load * 200W
Maximum Power Output 1600W
Variable Low Pass Filter 50 ~ 250Hz
Variable High Pass Filter 80Hz ~ 1.2KHz
Frequency Response -1dB 10Hz-40Hz
Signal to Noise > 100dB
Input Sensitivity 200mV ~ 6V
Input Impedance 22K Ohms
Operation Voltage DC 12V
Speaker Impedance 4 Ohms
Crossover Switch Selector HP / LP / Flat
Fuse Rating 30A x 2
Dimensions (W x H x D) mm 270 x 60 x 384
* @ THD < 0.5%, S+N 13.8V
this is mint £50 07815438987
  • Views 311
bump
