Door pins
ok guys I'm fitting a central lockin kit soon and I am wantin flush door pins! I no the 6n2 pins are easy but they don't sit flush, what about mk4 golf pins?? Any suggestions?
  • Views 1.2k
do you want them flush when its locked ? if so you could unscrew the pin and then cut some threads off the mechanism then screw the pins bk on and them they should sit lower down. in theory
Yea flush when lock so thrives can't get at them! I don't really wanna cut my mechanism down cheers tho
you only cut down the bit the pin screws on. i done it and it took 2mins to do both i only needed to snip them at the bottom of the threads and the ruffness of the rod held the pin on.
check out my thread in the photo gallery and half way down there is a pic.
Kuszpit :D
