Plank question...
feel like a douche for asking but what kind of roof racks do i need for a mk4?
its to carry a surfboard down to the coast, would halfords sell them?
cheers dan
  • Views 666
You dont need racks at all mate, get a set of soft pads to stick at each end of your roof (Dakine make em), whack the surfboards on top and ratchet strap em down. Boards will be solid as a rock and has less drag on the car too, been doing it for years.
sweet, do you strap them through the windows at the front? what about strapping them at the back because I'm only got a three door so couldn't go through the windows if you see what i mean. where can i get these pads from?
cheers mate
Can just about get em through the front windows, if you keep em far apart enough and you are confident that its tight. But u can open the boot first, wedge the strap under the hinges and then just strap tight as normal. Should work jst aswel, as for the pads, they can literaly be anything, pretty much any surf will sell (called Rack Pads i think) or just anything to stop the boards touching any paint work and to stop em getting dinged as u tighten the straps.
