uh oh help!
as you can see in my other topic i just bought a mk2 coupe with mk3 dash in it, I'm half what from taking hte engine out when i went and read max's mk2 16v build thread as i bought the GT engine and loom off him he ran it in his mk3 before the 16v.
I'm worried as he had to modify the connecters (check his build thread from the start) to fit to a mk2 but mines got a mk3 dash with working rev counter are they going to be the wrong connectors now?
hopfully someone will no like a mk2 god like max or 86c ?????
cheers perry
Edited by perrygt
  • Replies 8
  • Views 1.4k
any help?
need help quick as engine is ready to go in now
Edited by perrygt
can't you just look at the connectors and tell? Loom will be fitted after the engine anyway so its not stopping you fitting that?
to be honest i dont even understand what your asking in the first part, I've read it a few times and i just dont follow the english lol
as far as i am aware, the mk2 is same set up as a mk3, all revolves around the fuse box, so I'm guessing whoever did the conversion has just swapped the entire interior loom, so if your wanting to put it back to normal then get a normal mk2 internal loom?
here is a pic to help
I'm still unsure what your question is tho lol
I'm putting a mk3 GT engine and loom into a mk2 with a mk3 interir loom i think. Is there any way i can tell if its a full mk3 loom or just a modifed mk2 interior?
will my modified mk3 loom plug straight into the mk3 interior loom?
if you look in max crox build thread on page 4 you'll get me.
cheers
you should have no problems, simply plug the gt loom into the fuse box and away we go
only issue i can think of is the rear fuel pump?
i have the GT rear fuel pump and the lines will it still be difficult?
