GTi Splitter
what do you have to do to a gti splitter to make it fit the mk4 16v bumper?
planning on doing it this weekend but could do with knowing what i have to do! lol
Matt
  • Views 800
cut all the clips off, then use self taper screws to bolt it to the underside of the bumper. It is easier to do if you remove the bumper
I found also cutting small triangular sections out of the corner parts once the clips are off helped bend it round to the slightly different smaller shape of the 6n bumper.
Also get a mate or 2 to help hold it in place while you screw it in place. Will look alot neater than if you did it yourself.
Edited by kwijibo_coupe
