HELP WITH STUPID NOISE!
hi my seats in my polo gti wont stop sqeaking!!! and the seats feel loose to me anyway so I've looked under them and can only see one bolt wich is summit to do with the seat belt buckle,anyone know how to tighten these seats??? thanks
  • Views 1.2k
:lol: if its a mk5 i think they the same as mk4 and only one bolt holds em on and that doesnt really tighten em up, check the runners on the back of the seats and where the legs go into the runners there should be plasic things on the end maybe one of those has come off or worn out
can buy em off ebay if they missing item number: 220411975765
Edited by Ian.Southall
yea is a mk5 I've tried everything,those plastic bits haven't really done anything because I've took them out lol they rattle shit loads :x
Thought the plastic covers were to lubricate the runners/subframes?
and to stop the metal runners touching the metal subframes?
as without them, theyll just scratch the runners and move about, making causing the seat to squeak!
Id get a new set of the plastic covers and put em on, see if it makes a difference
also its really easy to take the seats out, one bolt at the front then slide em out backwards, have a check underneath like
were bouts the bolt??
its kind of if you sit in the seat and push it all the back and then look between you legs you should see it
its quite small and i think its a 10mm socket and an allen key to remove it
Yeah seat all the way back, its a tinly little Allen bolt and 10ml nut
take this out then slide the seat out towards the rear of the car then will lift out,
i was surprised at how little was keeping the seat in lol
great!!! ha ha now i can shut it up ill take them both out an tighten up stuff, thanks guys :-)
