HELP ,drivers WINDOW
HI NEWBIE HERE, i ve got a polo p reg dragon green , drivers window / eleccy, has stopped workin ,wont go up or down , it did but has just stopped. had a look an the cable and is loose near the front end , ANY ADVICE OR INFO WOULD HELP, CHEERS....
  • Views 758
If you take the motor out theres a bit where the wire wraps around about 6 times under the cover it may have jammed inside there. Thats what mine did, i took it apart but took about half an hour to put it back lol. Only do this if you know the motor is trying to work (the engine kinda slows down when you hold the button if you know what i mean) If not a new regulator is in order.
the motor trys to work , when you press the button up or down it makes a buzz , sound. but no movement, cheers .....
