Open air issue
didnt know if this was the correct place to put this, but here goes.
well, to start i own a lupo with a open air roof, but I'm sure they are the same roofs that come out of the polo open airs arent they? and i thought more people might have had dealings with these than lupos.
Well, I've been having problems with the roof from day one. so I've been working through the problems slowly fixing them as i go along. now I've got to a stage where I'm completely stumped.
I've got it so the motor now runs in both directions but when i go to open the roof only one side pulls itself open abit whilst the other stays in the closed position.
does anyone know how they work properly? like the mechanism inside?
or does anyone know what the problem with it may be? I've heard it might be the track or teeth but I'm not too sure because when i press the button to open the roof... the top lifts up slightly on one side but doesnt on the other.
hard to explain, but ill try get some pictures of it up.
cheers
  • Views 5.4k
found this on the clublupo forum, might help ?
http://forums.clublupo.co.uk/index.php?showtopic=53728
yeah I've had a look at that one. think hes having similar issues, but both sides of his roof moves lol.
____________________________________________
just nipped out and got some pictures of the roof on my phone, so quality isnt going to be brilliant.
this is the roof starting to open
this is the other side of the roof, whilst the other side is open like in the above picture
this is as far as the roof opens untill the motor trips out
and this is the other side again, whilst the other side of the roof is open as much as the above picture
these two show the angle the roofs pulling itself at
I would say the mechanism of the actual roof is broken, the only way to investigate further would be to take the roof out completely and inspect it in closer detail.
coincidentally I have a fully working open air roof for sale, the only problem is there are two tiny tears towards the rear of the roof. What you could do is strip both roofs down and transfer the material from yours to the mechanism of mine.
I'm after £80 for it, if you look at some of my previous threads there should be a for sale one for it. pics in there.
whats the actual running mechanism like on the roof? because i cant get in to see it.
how easy/hard is it to transfer the material over roofs too?
because if i cant fix it myself, or if the materials are easy enough to change i might have it off you
I'm not 100% how the mechanism works dude as I haven't stripped any roofs myself, all I did was drop my headlining and take my roof out and drop my new one in.
Regarding the material I would imagine once you take the underside lining off from under the roof the tabs which secure the material on would be quite easy to see and undo from the mechanism.
You could take your roof off and experiment with that, see if you can fix the mechanism or buy my spare and experiment with that
Alternatively I don't think anyone who is experienced to retrim/repair roofs will charge much for swapping the material over.
Try http://www.tudorwebasto.co.uk/ who are specialists in webasto roofs
or a quick google search reveals this off an aston martin forum:
I would reccomend a chap called Peter Harvey who is a Webasto Sunroof specialist but also does them for Weathershiled and Britax etc. he did the one on my MGBGT far cheaper than anyone else and it was a great job, his service was also very quick. tel No. 01304 614412 or mobile. 07956 292376
Hope this helps
