Steering wheel wobble
I did a bit of searching but I couldn't find a similar thread, unless I missed it.
In any case, my steering wheel wobbles from 60-80mph. At all other speeds it's pretty solid. I've had the wheels balanced twice now, yet the problem persist.
What could be the problem?
  • Replies 20
  • Views 1.6k
i had the exact same problem.
have you got budget tyres on the front? if you have that could be the answer to your problem. I've just put potenzas on mine and the wobble has gone
Have you got the correct size spigot rings?
I don't think it's budget tyres. I have been using 25quid budget tyres for years now on my car, and never had any problems...but when I had my alloys it was horrible.
the problem is your wheels are out of balance. nothing to do with what tyres you have..
joel the reason yours has gone is because they balanced your wheels after fitting new tyres. i have this problem on my ibiza that i haven't got round to sorting at work yet.
wheels might be buckled therefore throwing the wheel weights out of balance either that or oin correctly weighing / balancing them on the machine
Edited by veedub_fox
Yep, I forgot to add when I replied, it has nothing to do with what brand of tyres.
It will be your spigot rings most likely - providing you have alloys - because you said you have already had them balanced twice right?
That's it eh?
I guess I'll get them rebalanced elsewhere. It's not a huge problem, but just rather annoying after a while.
EDIT: Didn't see the new posts above.
I've got alloys, the 14" VW alloys that the car got at the factory. Now I'm clueless, where's the spigot ring on these alloys?
Edited by MehMan
That's it eh?
Have you got alloys mate which require spigots?
Eeek, a new post while I was editing my previous one.
But, I've got the 14" Vw alloys that the car got at the factory, do these need spigot rings?
hmm, if they were from the factory the centre bore should be spot on, therefore no need for spigot rings.
I just can't imagine it being balancing that requires doing especially after having it done twice..
i would of thought they just need balancing proply
are you runing spacers or spigot ring?
He can't run spigots on the VW alloys, because then the wheel won't go onto the hub.
But good point about the spacer. If you are running one, take it out, check all the bolts are tight etc.
Nope, no spacer.
Probably just needs rebalancing, I'll do that when I get some time. But at a different mechanic.
sorry miss read :lol:
Nope, no spacer.
yep id get them balance checked at a differant garage my cousin has had his wheels balanced wrong before
i have also got a wheel wobble at 60 - 80, its been there since i got the car - I'm also running budget tyres on the front wheels
mine were balanced twice and mine are standard valver wheels
I Do Tyre Fitting As A Job , It Could Be The Balancing Of The Wheels , If Alloy Probally Check For Stick On Weights ... If None Defo Need Balancing .
Another Common Thing Could Be The Tracking , Will Need To Be Sorted By Machanics .
Worn Tyres May Also Effect . And Inflation , Make Sure Its Correct
Hope It Helps If You Still Need It !
I would have suggested tracking too. You'd be very unlucky to have two mis-balancing. Have you had the car lowered, or have you changed the rolling radius with these new alloys?
H&S
Oh, and you may want to move this to the Suspension and steering section
:-D
H&S
I had tracking done a few days ago along with my aircon, and that didn't help with the wobble. And I think they mucked about because I can almost swear the steering wheel isn't straight on.
The car is bog standard, no modifications whatsoever. There are plans in my head after I sort out most of these niggling issues.
Will get the wheels rebalanced as it's the cheapest thing to try and then report back, cheers everybody!
Edited by MehMan
my 6n2gti does that wobble thing, its on standard wheels and has falken tyres but mine only does it when i accelarate between 60/80mph :?
check wheel bearings and wishbone
