Door Card Clips
I'm looking to make my own door cards, but i'm unsure of how to bond the clips to the rear so that they can slot into the holes in the door, and not tear out if i need to remove them. Anyone have any ideas on what the factory uses, or any other ideas?
H&S
  • Views 1.6k
I'm thinking some sort of epoxy(two part)that won't melt plastic or some sort of hot glue you would use with a heated cartridge gun.
There also might be some sort of ciano (super glue type) glue but not maybe good with moisture you can get in cars.
I'm sure someone else can pinpoint something?
tiger seal?
Whats tiger seal?
Thanks for the help, keep it coming :-D
H&S
Contact adhesive's the gear for the job, though a glue gun will work.
I thought contact, but i was unsure of how it will stand up to repeated removals. Plus platics difficult to stick. The clips on the door cards look like they have been melted on. Is this some type of glue like you get in a glue gun?
H&S
araldite? or similar?
Yeah, think thats what i'l use, and what folks seem to be suggesting.
Cheers for the replies
H&S
