Question...
i have recently acquired a set of lowering springs and shocks, which i will be putting on in the next week or so ....
i hve also just bought myself a set of alloys .... they were from my m8 ... who has buggered them to shit ... now i decided to re-spray them
but what with bug jam cumin up like next month i wanted to get them all sprayed up and on the car sharpish ...
heres my question .
i want to get the wheels done and dusted now,
so is there a primer i can use to spray over the bits i rub down and the lacquer aswell.
or am i going to have to rub it all down ??
it dont bother me if i do... I'm just tryin to save time ..
thanks alot,
chris
  • Views 718
If you want a decent job, your going to have to spend some time on them really. you could mask of the good areas, and spray the damaged bits, but it'l be hard to blend, an will probably look worse! Bet bet is to have em looking rough for bug jam, and spend the time after making up look good after. Prep is 90% of the time spent refurbing, so any scrimping will just mean poor results, and you'll have to do them again. Plus, your unlikely to save any money either in the long run.
H&S
after careful consideration i think i will go with what you said ... i wont bother putting them on for bug jam... and will spend some time on them, i want them to really compliment the car.. so the more time i spend on them the better they will look... hopefully :),
thanks for the advice :)
Chris
