Touching up
Is there anyway to fix a scratch that's too deep for a T-Cut without a full panel respray?
Got two small scratches on rear o/s, but they're down to white and can def' feel them with your nail. Just infuriating that they're only short but apparently require the whole wing respraying...
Any ideas?
Moral of the story- Don't let your girlfriend lean on your pride and joy when wearing a studded belt :x :-X
  • Replies 10
  • Views 1.4k
only thing i would sujest is get some 2000 grit wet and dry to flaten the inflemed edges of the scratch and get a touch up pen and t cut in after , or use colord tcut :-D hope this helps
If you want to do your car any good, dont put T-Cut anywhere near it..
You can machine polish over scratces that are as deep as the base coat and make them alot less visible... it's basically just a case of using a compound to round off the edges of the scratch then using a decent polish or wax with fillers to mask the remainder of the scratch..
Thanks, might have to give it a go, can't do much harm.
(In fact I probably can)
It's just not pretty!
Oh and as they say ''the proof is in the pudding..''
Oh and why not to use T-Cut.. modern (or decent) compounds and polishes break down as they are worked into the paint..
T-Cut doesnt break down.
That does prove it, undoubtedly!
Off to work I go, ta! :p
Now worries dude, I'm a bit OCD as you can tell :lol:
check out www.detailingworld.co.uk for info on anything like this :thumbsup:
Chris.
Chris.
Wow, that was a really good repair job!
H&S
Shows what a simple polish can do, and saves spending loads on respraying the panel..
So what did you actually do and use?
H&S
