The BoraT build - Holy SCHMIDT.
and now for the reason i'm on here at 2am, just finished doing some jobs at the unit - the polisher finally got my bits done today so had to take some quick pics of his handy work
stainless custom hotside pipe highly polished
inlet mani with threaded servo vac outlet polished
and the all important stainless bulkhead heatshield
once the heatshield is mounted i can actually start bolting the engine back in and make some real progress again [<:o)]
  • Replies 329
  • Views 32.5k
Very very very Nice :-) :thumbsup:
Best Bora in UK? :ninja:
I think so! :-D
thanks FoleE and Jamie - doubt it's close to best in UK. :lol:
got my hands on some vibra technics mounts, i also ordered a new set of spark plugs too.
there's not alot of pics because i started working on my car at 8pm and got back in at gone 2am, now everthing had to be done in order so i mounted my heatshield on the bulkhead
then it occured to me that i hadn't sorted out the mani heatshield so knocked one up out of some stainless
now i fitted the new clutch and 6 speed dmf
and thrust bearing / slave cylinder
also with the heat shield done i could fit my turbo with lines and DP
next i popped the box on and slid it into position with starter, from there she was about ready to go in so wheeled it an and bolted it up to the new vibratechnic mounts
also trial fitted my boost pipe
and popped the front end on
that is all for now
wow wow wow!
Some major progress going on here!
is looking so clean and smart, loving it!
i better get some pics up of the little things that have been getting done recently.
i mounted the polished inlet with new gasket and white injector seats
bought some more braided 8mm fuel line and some dressing ends
and fitted it up along with my boost pipe
also popped on the throttle body
and trial fitted a boost hose
next problem was the water pipe that runs around the block to the heater matrix, the pipe for a k04 is different than for a k03, i'd bent it around out of the way before but was never happy with it
so i chopped it down and welded the end back on it
now all i have to do is make up a new section to join the black pipe to the heater matrix, making it look neat and clearing the turbo / TIP
so i bent a bit of pipe to the desired angle and gave it a quick polish
then joined both ends with some silicon hose
next i order these from vw to fit the 6 speed box
i'd originally planned to throw my carbon fibre cover out but then thought it'd fit in well with my carbonio so reshaped it
then a good mate of mine donated me a different CAI so i'm not sure on the carbon again, but trialed the new CAI and i like it so have sent it off to be polished
i have finally got myself a decent boost guage after my inaccurate budget item
came with pillar off Edition but i donated that to Edd
started on my new servo vac outlet, i had originally bought a 45 degree adaptor but found it hit the boost pipe so got a 90 degree the other day and it just sneakes in
got my new bottom ball joints through to so popped them on
also split my scmidts down too
here's how my engine bay stands at the mo, i refitted the scuttle, ecu and aero wipers earlier, will have to see how long a few parts take to finish off this week
wow... stunning work!
Amazing work mate as usual! Need to see this in person a lot of hard work gone into this!
got rather lucky with the servo vac outlet then ay, does it touch the boost pipe?
Looking so good, is looking very awsome, neat and tidy!
epic project dude ! :thumbsup: keep up the good work
a pic of my ever so interesting new 6 speed outer cv joint fitted - only because it cost me £190 with discount :shock:
after work today i got the cam cover i had delivered yesterday from a fellow member and started to prep it
washed it down
removed the covers
sanded and keyed it
cleaned it off with acid to remove any grease
layed down the first coat
then 4 hours later the 3rd heavy coat
i wanted to not have everything polished so i thought this would tie in with my TB and boost pipe (cold side)
also as pointed out by albad the connection for my servo vac outlet in red and blue anodised stuck out like a sore thumb. i soaked it an TFR for a short time and popped it over the buffing wheel and got most of it off
thanks d.watson, Dooleyz, dub17 and m4ttj4mes.
starting to look like a car again now, think i just ruined my target of back on the road by August, just spoke to Andy at TUK and ordered air ride, never been a true fan and have always ran decked statics but it's just not practical in my area to achieve the stance i desire.
maybe that makes me a fag now - guess i'll have to run the rallye rep super low on coilys to make up for it :lol:
This is some serious comperhensive build. Finish on that cover is awesome :-)
Air ride. You'll be king of the scene :lol:
you are going to have to seriously drop that golf mega to make up for baggin' up the bora!
So will it be ready for edition?
demolover - with my exhaust i think i'm more heard not scene :paranoid:
dub17 - hope so bud, this is the new plan. :thumbsup:
Wow.
That is all.
Ha. Hope to hear it at some point. Vids needed when completed.
Was only kidding regards scene. A car that size and weight justifies air ride :-) When do you want to have it finished by??
I'm not, i want that golf diggin' up tarmac! :D
Edited by dub17
If i spent all that time and effort on the engine the last thing i would want to do is tear the sump off on a speed bump.
thanks fellas, starting to see light at the end of the tunnel now.
i got my centers back from the powder coaters when i finished work - i was far from happy with the finish, i could have painted them myself better than that but thought i'd better get them done 'properly'.
they were almost chalk board finish when they should have been gloss black.
a quick call to my mate polack (valeter) and he came and cut them back for me and will do them again in a weeks time to enhance the gloss.
got them all bolted up and bought them home
they haven't turned out bad in the end all things considered
youre my favourite
thanks Glen :paranoid:
after the failed attempt at polishing my intake pipe i decided to wrinkle black it although it didn't come out as well as i'd hoped. so after leaving it over night decided to trial fit it and get some pics with that and the cam cover on.
the filter i got to sit up quite high so should reduce the chance of sucking up any water
while i was messing about i thought i'd get a wheel out to try on so i can get the spacing spot on to how i want them to sit. so lowered the rear beam and popped the springs out, fitted the wheel and jacked the beam into position so i could measure the arch gap.
Those wheels look fucking epic dude!
Really really suit the car!
Never commented before, and just read da whole thread. You are really talented :thumbsup:
Keep it up man, loving it!
You're making me want a bora of my own now :D
thanks for the kind words fellas! :-D
did a few little bits today;
spaced my wheels out so they sit how i wanted - flush with the arch
fitted and wired in my newsouth boost guage
i split the ends off my old 5 speed p/s pipe and went to Pirtek with some measurements and had them make fit the ends to a new HP pipe rated to 3600psi so it should hold out
i also dug out my bumper to see if i needed to make any adjustmentswith the new filter / intercooler pipework but it fitted spot on with plenty of clearance
it's mostly all the fiddly little bits to do now and fit the air when it arrives
Edited by polo6n2g40
Got to love your Bora olly! Such a sweet little nut!
Will admit - I LOVE how close those wheels are to the arches :drool: wish I could afford to do something like this :(
