Door locks...
Wasn't sure where to put this, so thought this was the best suited area.
I have a T reg MK4 Polo.
Basically, for quite some time this has been an annoyance. Here's what went down:
Someone tried to break the lock on my drivers side door and succeeded and the freewheeling mechanism kicked in, so therefore a new "paddle" and "cage" were required within the mechanism. (The long rod with the flat "paddle like" end and the casing that surrounds this. So, I went to VW got the parts I required and off I went. Built it all back up and there we go.
Cam around to fitting it, and did as they said, insert the key so it is straight, place in and tighten up the lock mechanism and door handle back into place.
However, when I try to open the door, it seems that when I turn it, the paddle is not turning the mechanism enough inside to push the lock latch up so I can open the door. There are no problems locking it when I turn it to the left however.
Does anyone know what the problem may be or if I was going about fitting the mechanism back incorrectly?
Many thanks,
Danny.
  • Views 689
Many thanks,
Danny.
right, I'm not sure if i may be correct here, but tell me with the mechanism, when you turn the key, is the paddle thing moving too?
when i bought mine, the passenger side had the same issue where the key was turning, but not popping the locks
however after fidling with it i found that the paddle part was not turning and the inner part was broken, couldnt be bothered to go to the dealer i decided on a quick fix - swapped over the drivers with the passengers locks to save the £££ :)
either that or it seems like the paddle may be a shorter size, seem people on ebay seling "lock fix kits" that apparently cure that issue... have a look, worth a try,
sorry i know I'm a bit vague with the details :(
