T Cut
Ok so i debadged the rear of my car but it has left fine scrateches on it, will Tcut get this off or cover it. How do i use Tcut as i have no idea and is it easy to do?
As you can tell i have no idea what so ever, so please go easy :) :p
  • Replies 14
  • Views 2.2k
Depends how deep the scratches are. I know i got mine detailed and it got rid of all the swirl marks etc.
Although i have read in other fourms that Tcut isnt recomended.
very small scratches, so there is a dif surface now and you can quite easily see it in the light.
What do you think would be best to do, or is it a body shop job?
any one??
Can you see the primer underneath?
if its just small suface scratches and marks then t-cuts awsome. just use plenty of it , but dont go on for ages becuase you could remove abit too much and see primer. after t-cut just wax it and it should be fine.
max
T-Cut is rubbish, it looks good in the very short term but does nout good for your paint.
If the scratches haven't gone through to the base coat and are only in a small area, get tyourself some Meguiars Scratch-X.
Dont use normal T-cut because its quite harsh and contains ammonia.
Instead,use T-cut metallic. Its in a darker red,metallic effect bottle. Its more gentle,and you dont get the swirl marks in the paint.
Yours is a metallic car anyway so the scratches are in laquer and not paint,but this is the case for everyone - its better on paint too.
It even repairs jumpy CD's.
Does the Metallic T-Cut break down Mikey? I know the normal stuff doesnt that's why i hate it, it's like sanding with only 1 grade of sandpaper instead of going down grades..
If you'd rather just pop to Halfords then order stuff online, Scratch-X is a quid cheaper than T-Cut, Autoglym Paint Renovator is also good, it's basically as abrasive as T-Cut but breaks down, and it's half the price.
basicly all it has done has left little scratches and taken off some of the laquer. i will have a look in halfords :)
i found Autoglym paint renovator much better than t-cut in past :thumbsup:
Paint Renovator followed by Super Resin Polish (on the whole car would help) then topped off with Extra Gloss Protection.
Should look nice.
ok cool thanks guys :) i will give that ago in the week :)
Got my brothers wedding now so cant do it today :p
:lol:
He did 3 sepearate applications, by hand, with the T-Cut and there were still swirls, he had to use the T-Cut Wax to get them all out..
And if you're good enough to use a rotary polisher properly then you wouldnt need to bother with T-Cut.. it obvioudly needs some skill to use properly, so you're best off avoiding it and using a modern, safer product..
