How to: Replace aero wiper blades
I bought a pair of aero wipers from the group buy on here a year or more ago and the blades have pretty much collapsed and lie flat on the screen, causing it to skid all over the place and generally be pretty crap.
So I thought I'd try to replace the rubber blades only, and managed to do it without breaking anything, so I thought I'd take some pics and share it. Maybe it's obvious to some but it didn't look obvious how to take them apart to me, so hopefully this will help someone else!
Start by prising off one of the two triangle-section covers that are each half the length of the blade:
Take one of them off completely:
Now the old blade needs to come out - I did it by cutting it any way I could and then pulling it all out (will destroy old blade):
Now the blade is out of the way, the two metal strips are able to move a bit closer together. Push them together at the end where you took the cover off, and pull the end piece off:
At this point the middle clip should come off in the same way, and it should all come apart easily now:
Then you can cut the replacement blades to length and refit as a reversal of removal! As far as I can tell the rubber blades are the same cross-section as the replacements you can buy.
I don't know what other brands are made like, but this will certainly work for the mk3 group buy a while ago, and should stop the horrible skidding without having to buy a new pair of wipers.
Ray
handy. My aero's (bought about the same time) are shot as well. But I'm thinking of going retro... and getting some regular wipers again.
old skool
Yeah I've gone back to my old retros too for now, but when these are shot I'll go back to aero I think.
