Removing/Replacing bumpstrips
well basically, i want to remove my bump/side-strips but there is a little bit of rust and bodywork damage so if i take it off it will look worse than when i had them on, so i was just wondering if anyone had any ideas?
suggestions will be greatfully recieved,
Dale
Edited by dub17
  • Views 903
Depends what look you want, but i like them without. But on a more practical note, it might be worth taking them off and repairing the rust. The rust will only get worse over time, so if your considering having them off anyhow, may as well repair the rust while you at it
H&S
do you just peel them off or are they pinned in?
i think on my old 6n they wer just stuck on. left hellova mess with the sticky strips tho, but just took a caramel wheel to it and it was fine. I'm sure thinners or a heat gun would do the same job tho.
cheers mate, il try them next week and see what happens!
