hubcap enquires?
well i went down the scrappy today and found some tidy merc polished hubcaps like oldskool kool so i bought them.
I've got a set of 13" steelies in the garage but they ovi dont fit right anyone done any hubcap moddin?
Cheers ill get pics up if required :)
  • Replies 17
  • Views 1.4k
Could try just cable ties?
na wnt work as the hubbies r 15"s need the mk4 polo steelies dnt have any were for them to go i dnt think :\
A guy on here put 15'' caps on his 13'' steels, his names escapes me, i think its got jon in it somewhere
where they merc hub caps?
what car did he have?
cheers :)
a guy i know has put 15" merc hub caps on his 13's just cable tie the buggers on!!! get creative with your cables ties!
it they were VW caps, was a white 6n, Think it was bigjon
You wont get them balanced on cable ties,they'll wobble. Also,the trim will be massively damaged if you get a flat tyre - just mounting a kerb slowly,or running low pressure is likely to damage them.
What you want are some 4x100 15in steels,such as G60s or the usual Renault/Vauxhall jobs.
Even if you get 15" steels there is no guaranteeing they will fit. The C class trims I had on my Lupo didn't fit the 15" wheels.
Cable ties are your buddies.
i got them on usin cable ties but it is no where near enuf of a gd fit if u no wut i mean lol how do i measure to see wut size they are? i really want them to fit flush on a wheel as they look pimp. they are also metal :), ill getty sum pics up :)
hello fella,
i fitted my 15" trims to my 13s and they did look pimp...but then i realised that they where gouging a 5mm deep ridge into the tyre! luckily i realised in time before i had a blowout, but i still had to replace both front tyres!
if i where you id either buy some G60 steels that are 15" with some low profile tyres that the trims will fit on or just do what i did and get the bolt cover hubcaps and colour code them to the body of the car.
hope this helps
Jon
hi jon cheers mate, i recognise u as I'm the kid that came up to u asking about your badge at an sovag meet a while ago lol.
althougb shame i didnt see your polo at the latest one where were u?
I'm looking into buying some 14" steelies now the g60 mini ones as they fit straight on lol, the cable ties were braking wen driving which is shite lol :(
i gotta get the wheels as they r proper pimpin hard lol :)
lol to be fair i forgot that it was on...was the week i had off an to be honest...cant remeber much of it...was intoxicated for the entire week :D:thumbsup:
buy some g60's and stretch the tyres, 165 50 15s, nankang NS2's like £34 each + £10-£15 fitting each from tyreland. thats what iv just got dropped on my new wheels.....until last night when one went flat, i didnt realise and when i did it was too late.... got to buy and fit another now and iv only done 100 fuckin miles!
bad times :(
Jon
G60s aren't wide enough to have 165s stretched over them. They fit pretty much perfectly.
i thought they where 7" wide?
Jon
6" ET35
snds gd mate ill have to c u at the next sovag then :)
I've decided to get rid of the hubcaps, aswell as a lot of other things which will hopefully end up meaning i will have enough money to fund some proper nice wheels, i would like to refurb them aswell. :)
just doin my steels done the centre caps a bit like yours jon but not as good lol. guna run the steels till i can afford some decent alloys as said above :)
lol fair plays mate, found out why my tyre went flat... i had a screw i picked up in it :( which rapidly deflated the tyre, fucking the sidewalls completely but luckily not shagging the rim, they had only done 100 miles! just had to shell out for another one :(
Jon
