gauges (amps, temp & oil pressure)
3 gauges up for grabs.
Never been fitted to my car BUT not brand new. may need additional hardware to get running?
Please PM me for more info.
  • Replies 14
  • Views 393
Yo how much for just the amp meter jon?
£10 posted each.
Could the temperature gauge be used for either oil or water temp?
I dont see why not. There is a length of wire on the back of the gauge with a metal probe/sensor on the end.
I can get a pic if you desire?
I'll take the oil temp one if it has a probe etc,
Pm'd
PM'd bk.
Any idea where you plug an oil temp sensor in? I think oil pressure can be plugged into the back of the head above the spark plugs on a GT engine, but no idea about oil temp.
Sump plug sender buddy...
Temp gauge sold.
Maybe I'm being a bit retarded here, but if you have a sensor in the sump plug surely its rather vulnerable and likely to be damaged by stones flicked up off the road etc? Especially as the sump plug faces forwards on old Polos.
Maybe the sensor sits entirely inside the sump to protect it?
It would be no more damaged than the wiring off the alternator etc.
only voltage gauge left..............
bump for voltage gauge ^^^
1 left....
