Buying a Mk2 Polo
Ok I'm new to this forum! I used to have a G reg mk2 polo for my first car when I was 17, I fitted a bodykit, lowered it and fitted 15" wheels that rubbed so badly on the rear arches :lol:
I now have a mk3 Golf Gti which I'm always having problems with so I'm taking it off the road to turn it around, anyway I'm going tommorow to look at a mk2 polo squarback, its 1988 model and I think its a 1.3l I'm just after any pointers really on what to look for on the car in terms of rust ect... the guy is asking £495 and the car has 73k cheers :-D
  • Views 1.4k
This advice on buying the square back type...
http://www.clubpolo.co.uk/forum/index.php?...vice+buying+mk2
also all these are relevant...
http://www.clubpolo.co.uk/forum/index.php?...ying+mk2+advice
For that money I would be looking for a clean example with 1272cc engine five speed coupe s would be a bonus and I think the Ranger ones are ones to look for (with bars on roof) Early German made ones are better made but to be honest the later Spanish ones have the advantage of not being as old.
Edited by MacColl
Yeah,i'll agree totally. Id just point out that a good shell is everything - find a solid example and other bits are easy to sort.
I've seen totally rotten '87s and totally rust-free '84s.
But you'll need to modify the brakes on a pre-86.
yea this is a red ranger! Should be cheap to run around in as a daily while I doo up the golf!, ill prob end up dooing this up also haha its addictive!
you say modify the brakes? are they poor? cheers :-)
I fitted mk1gti calipers (from a mk1 caddy) known as vwII calipers but as discussed on here with the car not having a servo you've got to get your foot down anyway. A bigger master cylinder, braded mk1 golf hoses are an option too.
As long as the brakes are well serviced I've heard that ferodo pads are really good on the standard calipers but this has been debated from thread to thread. This leads me to servicing being everything with these 20+ year old cars.
Spend some time on the search engine on here... in fact here's a thread from before..
http://www.clubpolo.co.uk/forum/index.php?...+Brake++Upgrade
Ranger sounds good. Make sure it's clean for that price.
Pre-'86 cars have terrible pressed steel front calipers with often labelled 'postage-stamp' pads. The later calipers are far better,using pads twice the size.
The VWII calipers mentioned (fitted to various 80s and 90s VW's) are just wider,so that pads with the same size footprint can be used with vented discs - but the standard '86-'94 set up is fine for most people.
