started removing me side strips
decided to take the side strips of my polo as it was a nice day had nowt else to do went from this
to this
  • Replies 9
  • Views 1.4k
did you pray for them to remove themselves lol
Looking good :-)
lol i was praying the paint did not screw up on removal of the strips
are they just held on with glue or sumin? i thought it would have been clips orsumin. thinkn about paintn mine the body colour ( when i find the paint code0
That looked easy was it? Because it makes a big difference to it appearance.
looks easy but isnt. safest way to do it (for me) was to take the strips off which leaves the tape on the car and then use a mixture of finger nails and thinners and white spirits. dont reccomend thinners if the doors been sprayed recently. well worth doing though! looks much better and almost seems to look lower :)
fudge wheels do the job at removing glue and stuff
also remember they do a job, and you will notice when you remove them, the amount of little dents that will slowly start appearing
I'm surprised no one has ever tried fitting some other kind of bump strips to a mk4...
thats basicaly what i did but got no thiners used wd40 to soften up some glue left i used an old bank card to slide down the strip and tape to leave the tape mostly on the car also used the bank card to gently scrape of most of the foam left . big tip is to wash the left over glue and foam with some soapy water to remove any dirt thats got into the top of the strips saves having grit there and scratching the paint oh and give it a good polish after all the glue and crud is removed
i could see they were doing thaer job from the amount of marks in them back one had a big dent in it and a slight mark in the body work underneath i might get some 6n2 ones and couler match them
