Roof Lining Dye?
I've sorted my car out so it's mostly black interior, looks really good!
My head lining isn't and it sounds difficult to fit a new head lining!
Don't suppose anyone knows of some good roll on dye that would work?
Meaning I don't have to take the head lining out I could just roll on this black dye.
Let me know :)
  • Replies 10
  • Views 5.4k
mate...the headlining is a piece of piss too pull out!!
I've done mine twice now and am currently rocking a full leather interior after retrimming it myself. if your local too me id be willing to help
start with the A pillars, they just pull off - put a little bit of force into it and theyll come away
B pillars - pull off the seat belt cover to show the screw, get a 17mm spanner and unscrew this, then it will just pull off the same as the A pillar
C pillar/rear pillars - repeat the same process as the B pillars to get the seat belts off, remove the plastic trim with a torque screw driver, there are two screws inside of them also, once removed, the pillar will just pull off
also there is another piece of trim on the roof at the rear which just pulls off.
with all that removed, remove the sunvisors and grab handles then just pull the headlining away from the trim around the doors
with the headlining out, you can cover or paint your headlining as you like
hope this helps, if not PM and ill guide you through
sean
Thanks for that mate,
I never thought it would be too difficult to pull out, it's just retrimming it from a new material or refitting it I thought would be difficult.
Do you think it would be possible to paint/dye it while it's in there? If so what with
Edited by danosborne661
Might as well pull it out, will make it 10x easier to dye. I know foliatec sell intesive colour stuff, but I don't know what kind of results you'd get with it. Best just to get some material and trim to fit
i couldnt find any die / or didnt looking into it too much
so i took everything out and sprayed it all matt black
not a single bit of ugly grey left now x
Ohhh nice, how long has it been like that for? Been holding up OK?
Would love to see it, a pic would be awesome :D
this was before i done the head liner but everything else is done
its holding out ok but does chip off something but the good thing with everything matt black you can just spray back over it.
I masked all the inside up and sprayed my headlining black using the dye in the faq and it realy sets it off and hasnt faded,flaked off etc (mk3) alot easier than taking it out imo and risk tearing it, however mine is vynl material and i think the mk4 is sort of carpet but should be fine as iv done all my seats and doorcards too, contrasts great with my 24 led white interior bulb 8-)
Edited by robertvdub
keep thinking about doing this like!
PM'd asking about what spray on dye you used, sounds perfect!!
