Buying Blue Temp Sensor from GSF
Well basically I think the blue temp sensor on my Mk3 is Knackered. So i went to take it off today and the coolant exploded out (as you imagine it would) in the process the little rubber seal pinged out to who know's where.
So i'm gunna go buy a new sensor tomorrow from GSF, will I get the little rubber O-ring thingy?
Thanks.
  • Replies 18
  • Views 1.5k
It came with mine.
if you order online then it adds it on automatically. just check when you pick it up that the ring is there.
Edited by Cymro
i got mine from vw and i did :)
Sweet, thanks guys.
be aware, I've bought 3 new blue temp senders to date, and all of them made the car run shite
Were they from GSF DK or vw?
Get a vag one! there like 17quid max.
DON'T BUY A BLUE SENSOR FROM GSF
They are crap they work for 6 months and start to pack up. My car has started running shite from cold starts and i'll put money on it being the GSF sensor. VW is the best way.
Edited by carver
To late, plus I'm skint at the minute so £17 from Vag is No good.
I'll buy a VAG one in 6 months time haha
buy cheap buy twice :D
i bought mine from my local vw dealer and it cost me £17.50 including o ring
GSF ones are shite, your best bet is going to a scrap yard and grabbing aload free, new ones just dont seem to work
i did some tests with some, one was a new VAG one, and that caused me problems aswell...
:ninja::lol: Just been to do that, bad times.
Well the GSF one doesn't fit and my fan still doesn't work.......I'm sick as a chip!
Should have went to specsavers.
Well been out for a drive with original Temp sensor. Temp has sat at between 90 and 100 degrees's the whole way, but i dunno if i'd trust it in traffic. I really need to get the fan to work!
1. blue temp sender is fuel related - nothing to do with the fan
2. the black temp sender controls the gauge in the car - they are notoriously dodgy.
3. the sender on the radiator controls the radiator fan.
The following might be an issue.
1. Black temp sender reading incorrectly (which on most mk3 is 80-90 ish normal, 100 hot, 105 fan kicks in hard)
2. Fan switch - if doesnt fit in
3. block radiator - espcially round switch, so not sensing when hot
4. blocked thermostat, so not allowing water to radiator;
Radiator and thermostat definitely aren't blocked as I've flushed the whole system out and replaced the thermostat.
I'll try the other two.
i've flushed a radiator, then had rad switch out and its been clogged up round there
