Help desperatly needed
Hi I've just painted a new fuel cap on my 6n.
I now want to replace the existing one with it.
does anyone know how to remove and fit the fuel cap? spent ages trying to figure it out today.
if any of you have a hayne manuel for a 6n could you look it up?
  • Replies 17
  • Views 1.6k
open the cap, two screws on right.
look at them and think about what to do next. . .
hahaha. epic answer.
wish we had sig's just so i could put that there.
Edited by Cymro
as epic as it may be!
there are no screws, not that i could see on the 6n
the cap has hinges, look at them, theres two screws.
no screws
maybe they are hidden
i no the mk2 has two screws, but i dont see them imediatly on the mk4
Where abouts are these screws?
should be pretty much the same as that.
ahhhh, my fuel cap is round!!!
stupid polo, why did zeeee germans complicate things!!!!
sorry guys, thanks for your help. but i need help with a round fuel cap if anyone has any ideas?
Edited by tor_webster
same principle applies.
if t'other half was here, I'd go take a pic of hers.
that would be a massive help
my fuel cap s hinge is on the end of a s type bend, and is behind the body work. even tried taking door cards off to have a look
BUMP
i need to remove mine as well, anyone know how?
hi i had a look at manual cant find anything about the filler cap.
Ill go out to my car on friday and have a lok at how to remove it,it the onyl day i have free to have a good look soz it best a can do
hey never got chance to take look at the polo had to go out.
Pull back the back seats and remove panals from behind here should be screw to unclip the filler cap.
ot totaly sure if this true but it seems right enought
  • 4 months later...
did this work i need to remove mine aswell
if its on a s type bend then open the fuel cap and look up round the inside there might be a coupe of screws resessed back up there somewhere! my misses ibiza was like that!
Tie a bit of string around it,and the other end to a tree,and drive forwards.
Fuel cap removed,sorted.
i had this exact same problem when i wanted to do mine. i didnt even take it off in the end.. but try get a small enuff mirror an torch to shine on the hinges, that way you can see the set-up. I would have dun that if i was smart enuff at the time lol!
