Removing rear seats in 6n
I got a tool to use but its not strong enough what shall i use to remove them. I know its a torx screw.
  • Views 1.4k
the middle bracket? can just use alan keys dont really need to take the bracket off thou can undo those clips
Really lol cheers.
sorry to bump this, but i've got a similar problem removing the rear folding seats in my 6N..
the bottom part has come out fine, but the seat backs are held in at the bottom by two allen bolts each side.. but i can't actually get an allen key in to the head as it's pointing towards the metal sides.
are these bolts the only way of releasing the seat backs?
if what i said makes no sense i'll post some pics of what i mean lol, hope someone can help
To remove the rear seats,
Fold both right down and you will see a silver washer like bracket. turn this round with a screw drive and lift the middle pin away from the centre and prize off. do the same to the other and voila. :D
If pictures etc are needed pm and i will try and take some.
Kuszpit :)
Kuszpit :)
cheers dude, i actually finally realised this.. only after sawing through one of the mounting brackets welded to the bodywork lol
thanks again though!
lol its simple changed my standard 16v to leather in matter of 20mins :D
