How to make my 1.05 spi polo faster (Please Help!)
Hi there,
i have a little polo fox 1043cc spi and its so slow! i was wondering if anyone has an idea of how to make my car faster but without spending alot of money. I have already given it a good service but its no good the car is still slow. please help
cheers
  • Replies 32
  • Views 4.2k
engine conversion or new car
polo>>>cliff
What sort of engines could i put in my car without needing to do alot to the car? eg -engine mounts?
I'd imagine that a 1.4 16v wouldnt be too much hassle, don't quote me on this though.
Basic ways to make it faster would be obviously an enclosed air induction kit, turn up the fueling on carb or get a larger carb from something like a 1.3 polo gt. Use higher octane fuel, make sure the engine is maintained well e.g. new filters, oil changed and everything cleaned out such as throttle bodies etc.
Then you could try de-catting it with a custom exhaust, get yourself a stainles steel 4-2-1.
That's pretty much it without spending major money, but at the end of the day, I wouldn't spend that much money on a 1 litre engine myself.
cheers mate,
i would scrap the car instead of doing any engine work to it but i actualy bought it out of a scrapyard and re sprayed it army green, so all i need to do is tune it up. thanks for your comments tho! :-)
gt
g40
would a bike carb set up make it go better??
Yes it would, very much so. Get some!
Rip the cat off and jam a pole inside it until it's giblets fall out, get a decent closed induction kit OR take the reducers out of the standard box and get some piping for it and performance panel filter (Jetex are good).
If you're feeling brave get the head of and do a DIY port & polish, there's a guide on here.
That's pretty much all you can do engine-wise on a budget.
Weight will make noticable differences too, dump the spare wheel and shed any unwanted weight... rip everything out, have a shit before you go driving....
going by this reply you've no idea what your on about! a 1.05 spi is fuel injected not carb, its single point so not compatible with polo gt kit (unless you are swapping the complete engine over)
the 1.05 is pretty tuneable on a budget with 55 bhp easilly achieveable (same power as an spi 1.3, but a bit less torque)
the bits you need are:
1. late spec 1.3 polo inlet manifold and throttle body (these are both larger bore than 1.05 and should be the same size as the throttle body fitted to the golf 1.4 spi without the need to modify it to make it fit.) if you want to go one step further you can port match the inlet manifold to the head to maximise flow.
2. a poloace chip works wonders with the inlet upgrade (if your on a mega tight budget some 1.3 ecus will fit and will give a little more go for next to nothing if you can find the right one in a scrappy)
3. a gt cam will give a bit more poke
4. fit a gt spec exhaust system from the downpipe back or just lop your backbox off and fit a cherry bomb (both will drop back pressure and free the engine up loads)
there is a big how to on these mods over on polo3.co.uk in the how to section, would be worth you reading it.
the mods wont turn it into a gt muncher but it will liven it up no end and make it pretty fun to drive as its a very revvy engine
Shite, I said carb didn't I, it was cam I meant as I'm buying one off a friend I think.
Sorry for my mistake again.
Edited by DubDanny
seems alot of effort for 55bhp? :S
4 hours tops, i had 53 bhp out of my 1st 1 litre without half the bits on that list, although it had had a head skim.
another 1 litre polo i did, i fitted everything off the list bar a gt cam and it would out accelerate a stock 1300 with ease
granted it may sound like a fair amount of work for 10 bhp, but it really isnt, think of it this way, its a 20% improvement on power for £50 of investment (if your frugal and dont mind shopping around for bits) either way its less effort than an engine swap, it just depends how much faster you want to go. if your gonna go for a transplant then why bother with a gt engine, when there are bigger and better things you can fit, 16v, aee, g40 etc.
I'm doing a 1.4 16v conversion into a mk3 just now...its more hastle than you can imagine!
How to make a 1.05l faster?
1.3 throttle body and GT cam usually work well but thats it.
best bet is to look for a cheap GT conversion, or G40.
so if you had, 1.3 throttle body, GT cam, late spec 1.3 inlet manifold, poloace chip, uprated stainless steel system and induction kit, what sort of power increase would you be looking at?
on average how much at the engine and at the wheels?
thanks for all the replys
my engine has decided to pack up as its only running on 3 cylinders and its over heating, we have replaced the head gasket but its still shit.
I'm looking for a engine to go in to my polo will a mk3 golf 1.4 8v engine fit streight in? i imagine a 16v would need alot of work to get it to fit.
cheers
Doubt that the 1.4 8v would go striaght in tbh, golfs are bigger than polos so mounts may be different....
ohh ok, thanks mate.
do you know of a realy good place to get a gt engine from? or any other engine that will fit in my polo?
wrong! if its the adb coded one it will fit
Id keep the 1.0 inlet, the 1.3's are alot bigger and will be too big for the ports on the head. Personally i wouldnt fork out for a stainless system (unless you can get one cheap!) Just get a second hand gt or g40 manifold/exhaust combo.
Do you mean ABD?
^^ yep, got my letters in the wrong order though! doh!
Hehe, now now Steven, putting an AFH into a Mk3 is actually a piece of piss. Getting it running is different!
so a gt exhaust manifold, and system would be worth getting? So keep the 1.0 inlet manifold. Can you adapt a 1.4 spi throttle body to the 1.0 inlet manifold.
polo>>>cliff
polo>>>slow>>>>>search function>>>work>>>>faster
bumpo
