How to tell apart a GT/G40 from a "replica"
Hi there,
Just interested in how to tell that a GT/G40 is an original and not a replica thats had all the inteior, archs, wheels, brakes etc... added to it? Reason being is i may be looking at a car which the person says is an original G40, however it doesnt have the archs and has a "Polo" rear badge. Obviously i know this can be done to make the car look lesser to be more of a suprise to other road users but want to make sure? Will the V5 provide any answers? Or if they've done an engine conversion and told the DVLA will the car now be registered as a "Polo G40"? Best way to tell/find out?
Any advice?
Leon
  • Replies 12
  • Views 1.7k
Hi there,
Any advice?
Leon
yer best bet logbook,
aeriel and sticker in the boot with vehicle data.
A replica will only be registered as a G40 if they have salvaged the I.D from one - so if its a G40 shell with papers/numbers,and has been constructed from bits. None of the shell's parts would be original,but still registered as a G40 you'd not suspect it.
An engine number matching the original,and at least you've got the shell and engine from the original car. There are numbers on all parts,they change regularly so you can tell if they're all from the same time.
There are laws on this,and a car can only keep its registration if it has a certain percentage of its original parts. My own car is close - with the body and engine both replaced,I'm running low on original parts - but the entire interior,wiring loom,most electrical components,all steering components,wheels,suspension,glass.. It all adds up and so is still largely the original car.
The G40's body was no different to a standard one though,as far as i know (but for a roof-mounted aerial,easy to retro-fit). This isn't always the case,many performance Fords have body modifications but most could be retro-detailed with genuine panelwork anyway.
With the VW's,you have at least got the specification sticker in the boot - tricky to replicate,though its possible.
spec sticker in the boot has the info on it if its a gt g40
also the areal on the roof
rear beab with antiroal bar in it ?
also no 1 seams to fit the stearing dampner that come fited to gt/g40 std
Thanks guys, great help ;)
You can't change the make and model on the logbook, so it'll be registered the same. G40's have a rear-roof mounted aerial, which a DIYer is unlikely to do, but GT's have a wing mount. Though if you're dedicated, you could change this.
Thats lucky as my car has no label in the boot :-(
Nor mine :-( but why would someone remove it? its not as if it can be seen
exactly. Maybe it was removed by a garage for reference at some stage although thats just a guess.
the wiring is probably tidier in the conversions :lol:
Id agree with jon as you almost need to hang upside down to read it.
I have things on the sticker that are not on the car, headlamp washers being one of them and fog lights
anyone can fit a roof aerial, they're £12 from gsf and you used to see G40 rear beams up on here all the time.
most telltail part to spot on a conversion, as most that iv seen have the steering damper is the ARB mount should have a cutout in it. 99.9% wouldnt even notice this as its only size of half your thumb nail.
I wouldnt even know where to look!
