treating rust..
hi there, just wondering if anyone knew the best way to treat rust on the car exterior, patches are around the rear wheel arches. anyway in which to do this without damaging the paintwork. cheers
  • Views 2.2k
the rust will have damaged the paintowrk already surely? only way to get rid of rust is to cut out or wire wheel it away and then treat with some kurust and then etch primer and repaint buddy
If you want a really quick/short term/budget fix, and aren't botherd about looks, then some old oil brushed on to the rust will stop it getting any worse. However, it will need to be repeated and wont cure the problem
H&S
To treat rust patches etc,
You will need
overalls,gloves and safety glasses
sandpaper grade 60, 200, 300,
wet and dry grade 300, 600, 1000
spray paint primer(grey or white primer)
spray paint colour(green etc)
David's Isopon P40 Kit 250ml
Davids Isopon P38 Repair Kit 250ml
2 pound hammer and mini chisel
sticky back stickers and paper
Optional needs
Second cut file
wd 40
plastic tub for mixing
brasso(metal polish)
1. First using hammer and chisel take away the paint around the rust until you get past all the rust under the paint and see only clear non rust metal.
2.Using sander or by hand,take grade 60 sand paper and start sanding of the rust, you could use the file for this.After you have taking most of the rust of.take the 200 grade sand paper and start sanding again until you have taking alot more rust of.Now take the 300 grade and take the rest of the rust of.
3.Now take grade 300 wet and dry(by hand) rub away the scratches.When it gets to a point where no more scratches or even some left over rust s going away.Go to the next grade 600.
4.If u got the 1000 grade wet and dry and brasso or wd 40.Apply some to the rust and then run away with the 100 grade until the metal is scratch free and rust free and you can see your face in it.Technicaly it should be a surface finish of 0.6uj but never mind that number.Clean area with a cloth ensure metal is dry and free of dirt
5.Make a template of paper around the area you want to fix up and stick it on with the stick back stickers.Now that it is rust free mix together the p40 rust filler.It should be a scope size of a golf ball to 3 drops of the hardner(comes in tub).once mixed together apply to the metal part.Try smooth the past out onto the rust and leave to dry for 15 mins.
6.Once this is drive smooth it all down with the difrent grade of sand paper and wet and dry.Dnt scrape it all of just scrap it soo it all smooth and level with each other.ie no lumps.
7.Now mix up more of the p40 and repeat the steps again.This is just to make sure it is coverd properly.Make sure when you have smoothed it all down it is level and flat again.
8.now do the same with the p38 and sand and wet dry that flat and level.(This is not totaly needed but makes it better)
9.Take yuor primer paint and evenly spray on the primer other the work area.leave to dry as directed on the tin.Once dry smooth down again with the sandpaper and wet and dry as before.Then apply another coat and leave to dry.Once dry make it smooth and flat again.
10.Now apply the colour spray paint.Leave to dry and once dry make it smooth and flat once again.After this apply another coat and leave to dry.
11.Clean up your tools and leave car to dry for 24 hours
12.ensure car will not get any rain/water on it
The p40 and p38 is not essential for the repair bit will help keep it from rusting up again.
All These products can be bought from halfords except for the brasso but it is only to give the metal a love shine lol
hope this helps
let me no if there any mistakes in this
thanks
Edited by trendyscotsman12
:o
That's bound to cause more problems than it is good :lol:
Rest seems about right. But you will need the laquer the entire panel ideally to get it to blend in!
I used a sandpaper drill bit attachment and then started doing away all the rust and paint until I got down to bare metal. The important thing is that you get it all off, not just the bit that's flaked off. There's a good bit around that's started rusting usually. If you're lucky it's all surface rust, if not you've got a bunch of these little .01 mm dents where the rust has eaten well into the metal and you can't sand it away. for that I use some rust remedy, turns the red rust into something black and then just filler(you will need filler, trust me on this, as you're sanding down you are taking away a small ammount of metal and it can be seen) sand it down, primer, paint, clearcoat(you will usually need this because most of the rattle can paints you get mixed are water based so they will go wrong as soon as it gets damp or it rains). If no clearcoat is needed just leave for a day or so before polishing it well.
Edited by MehMan
haha you chip under neath the paint that is outside the rust,as there will be paint that is still on car but has rust under it,a dnt mean chip directly at the paint causeing dents in the car.A mean more to tap it underneath the paint and lever the paint off
Oww a forgot the laquer damn lol
