boot popper
ok guys done troublestarters boot pop mod on my 6n just wondered how to get it to lift abit as yes you guessed it i am really lazy lol so i want a nice solution that looks good as well as works, would uprated hydraulic lifters do??? cheers!
  • Views 1k
i assume its the same on a 6n, but on mine there is little rubber grommets by the lifters....you can unscrew them a bit which gives you a bit more lift when it pops.
hope this helps a bit dude
I though thy but when I checked they don't actually unscrew!!! LOL
Ok so I found out how to get them to unscrew ( take the rubber end caps off and use an Allen key down the hole then pull them out!!! ) but it's just not enough pop! Any ideas maybe some springs or summit what have people done? Let me know! Cheers!
