Best place to jack a mk3
I've been doin a bit of work on the underside of my car just recently and i woundered where the safest places to use as jacking points mainly for the front, i can see a few obvious ones but I'm just abit unsure wether they will take the weight of the car safely.
any ideas???
  • Replies 16
  • Views 4k
not on the sill flange!
you'll just fold it over and they'll look pants!
the jacking points VW specified.
also if you're going under it on a widow maker, remember why it's called that. . .
try not to jack it off.
What jack are you using?
If its the VW one then use the jacking points as stated by VW. IF its a trolly jack then use the flat jack points at the front of the car and at the rear I use the rear beam.
Don't work on you car whilst just supported on a jack use axel stands!! :)
after all the pikey things I've seen on here i'm assuming not all polo owners have axle stands though.
if you don't, use some bricks. . .
deffo use axle stands, mine fell off the vw jack tother day, i live on a hill so it went straight into the front of my mams car, got a nasty ding where the numberplate bolt went in my bumper :(
cheers guys, widow makers are a big noooooooooo as I'm sure we have all learnt. and yes rich I'm one of those pikeys who doesnt use axle stands but i think its getting time i got some.
the flat jacking point at the front is where i was thinking of jacking it from but wasnt sure on strength, i shall give it a bash tomorrow i reckon.
I'm guessing axle stands aren't cheap either
Yeah dont use Sill, the previous owner of mine must of!!
Its folded to shiz :(
axle stands are cheap and well worth it.
ahh yes I've just done a price check, not too bad although i did get my bricks for free and they have still got plenty of life left in them :p
throw them at something?
best place to jack a mk3?
probably at the trafiic lights
Stop being a pair of idiots.
for £20 there is no reason not to get Axel stands.
My axle stands have a U shaped fitting on them so for the front axle stands I made some flat square pads out of wood which with some grooves cut for the U shaped bit on the axle stand and which then gives it a flat top to rest the car on.
and to slide off. . . .
they're u shaped for a reason.
