vinly roof
anyone know where abouts they do it and how much I'm located in chesterfield
and the price :D
  • Replies 10
  • Views 1.6k
It's easier enough to apply it on the roof yourself, just have a look on eBay for vinyl suppliers and ask them for whatever size you need, cost around £30 irc
I got some vinyl from my dads work for my mates passat, and a window tinting company said they'd do it for £40. If you were going to do it yourself you'll need to remove the aerial by peeling back the headliner and undoing the screws. Common sense really if you're looking for a decent job!
Edited by Polo_GL
ill be smoothing the aerial off anyway
the seals gone round it and i dont liten to much radio:S
so just weld a plate in and smooth off :D
ill just shop around for it when i come round to doing it
mmmm interesting idea. need some pics of the job done before i consider it further....!
if your welding it y dont you just paint it mate??
not a fan of vinyl myself but each to thier own.
well yeh but paint cost more than vinyl :S
I'm wanting a dark purple to match my interior if i keep my leathers if not it will be black.
sod smoothing, vinyl the roof and put a rubber grommet in the hole.
costs all of £20 in total.
& if you dont like it, peel off and put the aerial back in. :)
That man talks sense!
where do i get all stuff for the vinyl from?
tbh Mate its not as easy as some of the guys are saying.
I got board one day after school and done it to my brothers car.
Only pics i have of it. sorry
First you have to measure the length of your roof and also the width. Then buy the size of vinyl need. (best buy more than needed) you can get it off ebay. (go for vinyl that lasts 7 years)
Then you MUST make sure the whole roof is clean with nothing on it.
Also remove the rubber runners as once the vinyl is on. the rubber will hide the edges.
After cuttin the vinyl to a size slightly larger than your roof keep it to the side.
You should get a scooshy bottle with water in at and spray evenly all over the roof.( This will stop the vinyl stickig to the roof straight away and will provide you with time to correct it) If you dont wet the roof the vinyl will stick straight away and may damage the vinyl if you try to pull it off again which makes it useless.
after laying it on the roof use your hand or a sqwegy spreader with felt on it to remove the bubbles of water. ( work from the centre out. )
once you cant see much bubbles. start to cut the vinyl to the roof and make it neat.
after doing this leave to dry for around a day.(Then after leaving it put the rubbers back on) Do not drive the car is it will lift due to the gap near the wind screen which will lift it all off.
Also you cannot wash the roof till about 2 days after. and if you use a jet wash leave it a week (as hard as it is)
That should be it mate
If you do it show us some pics of how you got on.
Kuszpit :)
