My Cheap/Free 6n mods :)
Hi all, thought i'd show you the modifications i've been doing to my 6n over the past week or so... because i just can't leave the bloody thing alone! haha
First off, split and smoked headlamps.
:) quite pleased with the results tbh :)
You can also see i've fitted a new bling badge to the grille, it has a matching one on the boot too!
Next up is my smooth wiper plynth
now you can buy these... or do what I did, make one!
I cut out an old bump strip and shaped it into a circular piece of plastic to fill the hole, then used a soldering iron to plastic weld it into the original plynth :)
Skim of filler later and you're good to go, knock it back with a block and then primer and paint :)
Next up, ibiza heater dials
The pic doesn't really show the benefits of this modification, but basically they illuminate red rather than green.
I also fitted various other bits and pieces of trim that were missing whilst I was on.
Not bad for cheap/free ey? :)
  • Replies 14
  • Views 1.7k
starting to put you are own mark on it starting to look good, when u homing to get it done or is it a ongoing task ?
may have sourced 2 more dishes for the BBS, allowing me to run poke and tuck :)
Tuck and Poke FTW!!
I'm sure Ibiza clocks go into these and light up red.
I dont even wanna know the bargain prie you brought that polo for :(
Is that a tin of pork I see on the right? :ninja:
Coming along nicely
ibiza heater dials- Were did you get that info/idea from :lol:
+ The clocks will fit mate i have a set in mine
Edit yer they do light up red aswell
Edited by Po*Low*
i still think you should split the indicators and smoke them aswell...
might smooth my bumpers tomorrow night if I manage to get a minute!
shouldn't be too hard tbh, i've had the bumper bits out today and there's no bolts behind them, so no reason why they can't be smoothed :)
I made a wiper blank back in the day, so easy yet people don't seem to bother :S
Whats that boost guage doing? I've got an air vent mount if you want it?
I think you should make it Dirrty and not a polo tart :-p
where can u get these wiper blanks from ?
