Spaced out 10mm EDIT - **or 5mm**
As above, or would I be alright keeping the standard one's on?
It's a MK3 if it makes any difference.
Thanks.
Edited by RobWhite1992
  • Replies 12
  • Views 1.7k
i think its anything after 6mm and you need longer bolts tbh, and think you should have 6 full turns on the bolt
Cheers; what size bolt do I need?
I know it has to be 10mm longer than standard but whats the standard size, if anyone knows?
measure them?
measure them?
The car's at my Dad's. :-(
measure them?
Both the length and the width.
measure them?
Please, someone know the measurements?
Use your noggin. Ring up a local alloy wheel place and say you want to know what sized bolts you would need for a 'insert year here' Polo.
it depends on the wheels dude
my borbets would have needed longer bolts even with 5mm spacers when i tried to put them on, but on my mattig steels, with 10mm spacers i dont need them because the faces are much thinner...
Ah right - I can get them on with 10mm spacing.
But the garage near me deam it as dangerous.
I counted eight threads,and wouldn't use less.
I've heard Mercedes are the way forward for longer bolts,but have no experience of it.
Cheers.
Would I need new bolts if I've spaced out 5mm?
Or would that we alright?
