has this happened to any one else?
i took my bumper off to spray it...
once it was sprayed, i put it back on.
but some how it raised up a little bit, and stops my boot opening.
to open my boot i have to push down on the bumper.
iv looked at it and there is no way to adjust it.
  • Views 1k
on a mk2 , strange , did you seperate the metal from plastic , if so metal bit could be wrong way up !
the only thing i ever had was the boot open on one when you pull away fast on bumpy ground , that car needed a bumper like yours :lol::lol:
lol
i only took it off by the 2 nuts on the inside of the boot.
Both nuts the same tightness? Probably need adjusting by the 2 bolts and the clips on each side of the car.
Both nuts the same tightness? .
both nuts are the same tightness.
( Probably need adjusting by the 2 bolts and the clips on each side of the car )
i take it you mean the black bits on the side of the car wich holds up the sides of the bumpers?
if so are they adjustable?
is it the right way up! haha only jokin!
just fiddle about wit um
The two clips are guides. Theres a lug on the inside of the bumper that slides IN the guides. Do you have the lug sat ON the guides? That may be causing your problem. Weird though, i thought there was quite a bit of clearance
H&S
