replacement panels
easy now pea poles
does anyone know if you can still get replacement panels for mk2 polos
i need a rear vallance peace, the metal around the tow eye is gone
and i need a filler neck surround
I think VW stopped making body panels for the mk2 around 2 years ago.
You may be able to get some from GSF or someone else, but it's not as easy as it use to be to get new. Plenty of old cars being broken though.
beevers and hadrians (on the net, search on google i guess). But i'd gor for a scrappy tbh, cheaper. Although that rear valance could be tricky to get off!
H&S
VW still had panels last year,they only wanted 70 quid for an entire rear quarter panel assembly,complete with inner wing/arch/fuel pipe surrounding panelwork.
According to the VW guy I spoke to last year, they only have left what's in stock. There are no more o/s/f wings left so you were lucky to get the rear quarter panel - unless they're still making some panels. When I bought the o/s/f wing, there were only 3 VW dealers in the UK on the system that had the part. When phoning round, only one actually had the part in stock and I had to get a part couriered half way across the country.
i've looked around i think i'll have to make the replacement pieces
bring on the tin bashing
did you try beevers panels?
H&S
