Tornado Red
Hi i am currently repairing some scuffs and bits and bobs on the car.
I have used grey, white, and red primer, none of them match to the original paint once the top coat is added. so fustrating.
Can anyone help me out
Rich
  • Replies 12
  • Views 3.4k
some one help me
Its likely the topcoat - its very hard to get right because the paint shade has changed so much in the weather,even if its T-cut and polished a few times.
I did a few patches on mine and couldn't get a red anywhere near - Ford Radiant red was closer than Volkswagen Tornado red..
agreed, tornado red doesn't age well at all so you're unlikely to get a good match regardless of primer colour. Ideally you'd need a bodyshop/paint supplier to custom mix some paint up to match the paint on your car.
1st off why are you using top coat? the correct primer to use is white primer. with a flat colour like tornado red you dont require laquer, you should just be able to cut and polish the fresh paint back up.
you really are best off getting some custom cans made up by a paint specialist rather than using the crap sold by halfords or other motor factors
By top coat i meant the tornado red, i got a can from ebay, hycote stuff, i first tried grey primer- was too dark. then tried white primer it was too light. then tried red, which was also too dark, is their a cream primer available?
Youll probalbly find that the variant of paint in the aerosol youve got is different to the one on your car. When manufacturers make paint they make it in massive batches. So some batches are gonna be different shades to other batches (thats why white scoobys are a different shade of white on each panel). Your best bet is finding somewhere that mixes good aerosols so they can get their colour charts out and mix you up some paint that will actually be the same as your car. Providing your putting a decent amount of paint on the primer colour shoudnt make too much of a difference (we only use grey at work).
I'm not sure if this is really answering the question but i was having similair issues when spraying a wing tornado red. it wasnt so much the colour matching in the usual sense more that it was the wrong sort of finish.. sort off. hard to explain but i used red primer and then halfords tornado red top coat, it was comin up funny then pops suggested applying a wet coat.. a wet coat i said? why what is a wet coat? so then he showed me and its like you put your top coat on very close to the panel so that it has a deep shine.. hard not to get it too drip but when it was done it looked an awful lot better than when i had been doin it my way..
so maybe a wet coat is what you need?
my panel looks pretty good now.. when its polished up with the rest of the car anyway :)
safe
I'm with evabot with this one. hycote and halfrauds stuff is ok for doing bits n bobs like mirors etc, but on a panel you really need custom mixed paint.
were you the guy i was talking to at the gaydon motor museum meet? if so there is a place in banbury which mix custom cans called colourmatch and they are very good.
Hi yeah i thought it was you ha. yeah i was at the gaydon meet. cool are they pricey.
might just get it done professiional fed up of many attempts
think they are about £7.50 a can, but they are totally worth it, as you can get really good results with them
I don't know why everyone has a go at Halfords. The paint they mix up isn't too bad. I repaired my wheel arches using Halfords made Indian Red and it looks like a rather good match.
its the most utterly gash paint, mixed up by plebs who have no idea as to what they are doing, thats why people have a go at hellfrauds paint! and to top off the fact that 9 times out of 10 it doesnt match, it almost always reacts with the surface to be painted regardless as to how well you de-grease it.
the only good paint they sell is the plastic primer which for some reason is really good
