6n2 gti bootlid on a 6n 16v - loom issues...
went to swap the bootlid on my 6n 16v or a 6n2gti - took the casings out of the back to get at the loom n traced part of it back to the clips then realized the loom is different - as far as i was aware this is normally a straight swap confused :? am i just looking at the wrong part of the loom? any help would be good right around now lol ta.
  • Views 1.4k
loom joins behind rear quater on a 6n
yeah i think i found it but the connectors are different thats whats throwing me :s am i looking at the wrong connectors perhaps - the 6n is like a cross with i THINK like 5 points and if there is another i gave up looking tonight it as i needed to reconnect the central locking pump before it got dark. so anyway - there is the cross shaped connector clip on the 6n and on the 6n2 there are two L shaped clips. given the 6n2 is a gti there is going to be wiring to the break light in the spoiler but because the 6n 16v has a similar (internal) break light option, i assumed the wiring would be fairly similar...
Why dont you use yoru 6n loom on the bootlid instead of sopping looms? check the other end of the mk4 loom (the side where things plug into the boot) and see if there the same as on the mk5.
thats not a bad idea ben 8-) if it comes to that i might have to give it a go.
exactly what i did i just chucked all my 6n loom in there and wired the third brake light on spoiler to the wiring for the light on the boot :thumbsup: you will need to change the catch on the boot aswell for the one off the 6n otherwise your interior boot light wont work its got differnt wiring too
nice one cheers lads, il get on it tomorrow. ian, where did you relocate you are license plate to? i was thinking of putting the plate in the dip/recess part on the bottom half of the bumper (so a couple of inches up from the bottom) then taking the original lights and essentially cutting two holes in the bumper in the top of the overhang and relocating them to there, so the plate is lit from the top, then smoothing the original holes. i know you can buy those little lights that clip on the bottom of the plate, but i feel like doing something a little different.
you got a 8v bumper or 16v?
Try fabbing a mk5 recess into a mk4 bumper ;) Or get a mk4 front recess and put it on the back then get them illuminated bolts :D
its a 16v bumper dude. i thought about fabbing a recess so it would be somewhat like a mk5, fair bit of plastic welding and fiberglassing. def do-able, but tbh the placement of the plate looks pretty good in the natural recess of the bumper, and it would deff be allot easier to do that! :lol:
