9n 5door rear door speakers not working?
i have sound coming out of the front doors and none out the back, and no i havnt got the fader set to front :) i have never realised any sound since i have had the car but annoying me now, the only way to get in and look at its removing the door card so how do i do this?
do these cars not come with rear door speakers as stupid as it seems or could they not be connected?
  • Views 1.6k
some do some don't
the only way to check is to remove a rear panel and check
how do i get it off?? would the wiring be there even if there isnt a speaker?
not neccessarily
to check for sure pull out the head unit and check the factory speaker plug if there are only 4 wires in it then there are no speaker wires fitted
if there are 8 then it will have the wiring
4 wires, what a load of shit lol, so how do i go about wiring it through isit hard?
its not hard but if you are using the factory h/u then it still will not work as the internal amp will only be 2 channel
the best bet is to buy a repalcement h/u and run the speaker cables to the back
