Gromit into engine bay
Hey I've got a mk2 Polo Coupe, I want to find a gromit on the driver side that I can drill through into the cabin from the engine bay?
I've had a look and I can't find any, it would be nice if there was one near the bottom of the dashboard.
  • Replies 8
  • Views 1.4k
I'm sorry if this is really obvious.
I've been looking everywhere for it online before i do I'll regret
Ypur question doesnt make any sense. A grommet is a rubber ring that sits in a hloe to protect wires running through it. So you wouldnt drill a grommet.
What do you actually want, a place to drill?
H&S
H&S
Erghhh for f sake. Yeah, I'm sorry about the wording I thought it was a rubber ring but my dad was yelling it wasn't. Guess I shouldn't listen to him.
Basicly I want a place I can easily put a cable through from the engine bay to the cabin and i was wondering if anyone knew of an easy way to do this?
ie without me having to destroy it
http://z8.invisionfree.com/POLO3/index.php...;st=0last similar to that except on the drivers side.
H&S
Yeah, tell him he's rong! :lol:
What are you wiring in, i assume its ice and you want to get to the battery?
H&S
H&S
H&S
Well it's a horn that needs a lever to operate it, a similar lever to the one that opens the bonnet.
Yes it needs to be wired to the battery. Thanks
H&S
H&S
So the grommet will just have the lever/switch running through it? Theres a gromet that the throttle cable runs through, big one in the engine bay. If you dont need to run power to the cab directly from the battery you could use this? I guess you could use it anyway, just have a long wire. It'll save you drilling a new one, and if it doesnt interfere with pedal action, could be your answer
H&S
Edited by prankstar2003
H&S
I guess it'll do thanks for your help.
