overheating?
my valver keeps over heating badly. i put a new thermostat in and it boiled it over straight away. my mates told to renew my water pump, thermostat and check the sender unit. any thoughts cheerrs
  • Views 957
mins just started overheating today,got multi problems lol.
I need a new thermo stat
i have holes in my raditor
i might need new water pump
and a hope to fuck that my head hasnt warpd lol
cars are a pain in the ass
sounds alot like the water pump. it went on mine at the same time as the stat and the stat housing (the "bridge" bit in the top gets a hole all the way through). i recomend NOT using a genuine vw stat as i had trouble with overcooling with one. got a pattern one in now and its fine.
cheers mate ill try that, hw much is a water pump?
i just had this same problem
theres two types of water avaliable from vw one is a bout 20quid and one a tenner more,i just got the 30 quid one just in case,you need to make sure you dont drive your car or you will fuck your head!
