mk2 gt bready?
right well I'm after a new resto project for the summer, I'm looking on wikipedia but it doesn't tell the story for me.
I'm interested in a mk2 breadvan, now i was wondering which was the quickest model produced in the uk? as i no they say they did a gt but was it produced in the uk?
also was wondering if these cars are rare? and if anyone has a cheap one?
plus what should i specifically look out for and how much should i spend reastically to find a fairly decent one?
Cheers, Joe
  • Replies 11
  • Views 1.2k
None were produced in the UK,but the quickest one exported to the UK market,in RHD UK spec,was the early '80s 1272cc HH engined version - with 60bhp.
The GK engined breadvan had 75bhp but wasn't fitted to a UK car.
Edit due to thinking the HK was also 60bhp.
Edited by MikeyMK
o so it would be well hard to find one then?
ok so I'm looking for a 1.3 bready then?
Cheers.
Yeah,later 1.3s had 55bhp.
would it be fairly easy to put a mk3 gt engine in it?
Well if you're not bothered about it being completely standard,you have many options. If you want more power but want it to appear standard for nostalgia/show reasons,then a change of bottom-end for an ABD one will take a post-86 car up to 1391cc,yet the engine will still look the same.
A GT block will up the compression of a seemingly standard engine if you just bolt the carb stuff on and dont bother with the injection.
You could even make a 1.6 look retro,but that's more difficult,and you cant run the MK2's mechanical fuel pump with that (or the above engines if you want to use their better cams).
If looks aren't important,you have far more choice! See Engine/transmission forum for further info on such choices.
GT lump will go in easy enough, and mk3 dash.
someone on here did it in the photo forum.
Look for a Ranger they're like a bread van except with roll bars, cool as f**k.
I had a go in one once and it was as quick as my coupe s that i had at the time
if the breadvan was a 1.3 then it would of had the same 55bhp engine in it as the coupe S. the S was just a trim level and had the standard engine it it.
yer engine looks doesnt bother me at all i just want it to be fairly quick, was thinkin carbs aswell?
looking to really turn it into a proper sleep when i get one :)
you might be in luck dude, I have a ranger you can have for cheap. no more than £150
GT bottom end, uprated cam, twin 40's...
