Tint spray
I bought some tint spray off ebay but it took loads of coats before it came out dark, can anyone recomend a good tint spray??
  • Replies 11
  • Views 1.3k
got a link? Black and i orderd red in the same make to but it hasnt arrived yet.
How dark are you wanting to go? You do need to spray a lot to go really dark, which tends to make it illegal as it fucks up the reflectors.
Black but i want the light to shine through well, I'm not botherd about them being illegal there for my brothers car lol, whats spray is good??
are you simple? you cant have ypour cake and eat it mate, if you go jet black ther will be piss al light through, hardly see it in daylight. hel end up being rear ended by sum half aslep driver.
this really winds me up. people always miss a simple, vital part of spray tinting rear lights. if you sand the lights first with p800 wet or dry, it will make the plastic go opaque (lighter in colour) this means you dont need as much tint to change the colour of them and therefore you wont reduce light output and remember not to go made on the reflectors, as they are there for a reason!
oh, and make sure you give them a good couple of coats of clear laquer as this will make them nice and shiney and stop the tint from fading off
I'm not stupid Hargy90, they shine through fine! All i want to know is what tint spray people would recomend that they have used??
I used some e-tech spray, it was the black stuff and I used it on my rear indicators,
only took about 2-3 coats, and it leaves it with a shine so no need to laquer it.
The trick is to do it on a proper hot day or just heat up the lenses with a hairdryer I found (Y)
Nate.
Thanks for a hepful answer mate. Thats the make i used, maybe it was just a duff can.
Hmmm, it worked ace for me, did you heat up the lense?
it can help sometimes for it's adherance and the finish and so forth :thumbsup:
Nate
well if you've already done it, its black enuf and it reflects fine, why in the name of god start this tread?
Because i thought there would be a better make that doesnt need so many coats and this can came out in thick blobs so I've got to redo them.
