My car tried to eat a muddy bank
Alright, picture this, greasy wet road, downhill, curvy road. Muddy bank straight infront of me, road goes right. So I decide to press the brakes and I guess I slammed them or just pressed them too hard, in any way, the wheels locked up and the car just went straight on, couldn't do anything because before anything else could have been done my car had gone into the muddy bank. Long story short, everything is fine, I hit it at around 20-30mph, wheels and all seems fine. I cleaned it all off, there was just a ton of mud on the front of the car, and in the left wheel.
The bumper took the most damage, the wheel well took some, it just tore them off. The bumper is now hanging a bit on the left hand side, not touching the floor, but it tore it off it's mounts. Gonna need to get some washers and get that fixed.
The splitter was torn off a bit too. I have the one piece front bumper, any tips on the splitter? is it a snap on kind of splitter or is it screwed on? Will have to fix that too.
But all will be for naught, because of this:
The bumper hit the frame and now there's this huge bump on it. It's quite noticable, is there a way to fix this? This is really my biggest worry and problem. Also, shouldn't have this triggered the airbags? At least I imagine it should've, I'm a bit confused here, worried that my airbags aren't working. In any case, I would really appriciate if anybody knows how could I get that back into it's former position.
  • Views 1.2k
body shop might be able to heat the plastic up and shape back how it should be, kinds like what they do for plastic welding i guess.
take it to a few places and see what they say.
The shell requires a shockwave to deploy the airbag/s,seatbelt tensioners,and cut the fuel off. You'd have to do far more damage than that.
The dent is caused by a collapsible steel crush cone underneath,bolted to the chassis leg. Chances are you didn't even damage that,just broke some minor trim.
This includes the 'bumper'. Well its not a bumper,just a big painted moulding - the bumper is metal and a seperate part bolted to the chassis legs (with said cones) underneath.
Its a moulded trim which is likely to be further damaged underneath and best replaced. Otherwise,just put up with it being as it is,as long as its secure.
Currently it is secure, doesn't hang or anything, it's just bent about half an inch backwards on the lefthand side. The whole bumper is in relativly bad nick(looks like somebody drove it into rocks or something) and isn't worth paying money to get it fixed, because a second hand one would be cheaper to buy and repaint. Still, I did manage to get the bump back in a slight bit by heating it up with a heat gun and pushing it in.
